remington_rand's avatar
Sep 02, 2021
Additional router to connect to MS80 mesh system
I have a mesh system with the Nighthawk MR80 as the base router, with 2 satellites. I'm unable to beam the wifi signal to my home theater room. The wall is made of kryptonite. Best solution is for me to run ethernet cable around the house to that room and connect to a second router to run in bridge mode.
What model Nighthawk router will do this job? Looks like the MR80 doesn't come alone, but mabye with one satellite.
Is there a router that I can use?
