StoneSword
Jan 23, 2021Aspirant
After Firmware update V1.2.0.66 wifi speeds are slow
I just recently updated the firmware on my WNR3500Lv2 router to the current version: V1.2.0.66 and noticed that my wifi speeds are slow.
For example, watching YouTube videos on my phone while connected to my wifi the video is in a constant loading state. Even downloading a small 50mb app takes 10 minutes.
Everything was fine until I updated the router's firmware. Any fixes?
Did you try factory resetting and reinstalling the router (not from backup)?
Its usually what's recommended if there's issues after updating firmware.
- StoneSwordAspirant
plemans wrote:Did you try factory resetting and reinstalling the router (not from backup)?
I did for a reset facotry on the router for about 30 seconds and still having issues. When I download an app on my phone over wifi the download speed is slow to the point it takes half an hour to download 100mb. The wifi is the issue and it has me stumped..
What gateway do you have?
What speeds do you get hardwired?
What speeds do you get over 2.4ghz?
