Questman99
Jan 08, 2022Follower
C37000 N600
How do you change the password on the NETGEAR 3700 Router ?
which one?
Login password?
https://kb.netgear.com/20026/How-do-I-change-the-admin-password-on-my-NETGEAR-router
or ssid password?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with. - michaelkenwardGuru - Experienced User
If that is the C3700 cable modem/router then for problems that are related to the hardware itself this isn't the best place to get detailed help. Your device doesn't fall into the category Nighthawk WiFi Routers covered in this section.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
As plemans says, you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
