Orbi WiFi 7 RBE973
Reply
Extremely disappointed in Netgear's customer service. NEVER AGAIN. NEVER.
DioRox
Guide
I purchased Nighthawk's to place in my rental properties. I have one for my home as well. Yesterday, I go change the wifi password as I have new tenants coming in. I make my changes, reboot the router, and I haven't been able to get back in since. I enter in the IP that I've always used, on all of my routers. 192.168.1.1. I reboot the device, power off, unplug, etc, cleared cache on my browser, tried again, to no avail. Finally I give up and call Netgear and explain my issue. The guy says to me, 'Did your warranty period end in November? I can't help you. The reason you can't get back in is because the security features and firewall that was free for the first two years has now expired, and if you want to fix the security issues you have to speak to our tech department, but there will be a charge for that.' So, I told him how unhappy I was that it seems that I'm almost being hijacked with ransomware. 'Give us money to get access back to your device.' He basically laughed and said that I have to pay if I want help. I told him that they're not extorting any more money out of me and I'll share far and wide about how terrible their service was. He thought that was funny too and told me to go ahead and tell anyone I can. It's really sad that they allow their employees to treat customers like that, after they can see how many registered products I have with them. He was a patronizing jerk and I'm sorry I've ever spent a penny on them. So now, I can't manage my router by web, nor the app. I didn't do a full reset yet but I'm sure that won't work either. Jerks.
Message 1 of 10
Re: Extremely disappointed in Netgear's customer service. NEVER AGAIN. NEVER.
Are you here seeking help with your router?
If so, tell us something about the device, what it is and what it uses to connect to the Internet, The modem etc.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
If you just want to complain that Netgear does not provide free lifetime support for every device it sells then there's isn't much help that anyone can give here.
This is essentially a user-to-user forum, with some input from a small band of Netgear techies. You can try the official channels for support, but be warned that, as Netgear explains when it sells stuff, after 90 days it will want money before talking to you. Much easier to try to sort it out here before you open your wallet.
Contact Us | MyNETGEAR
Message 2 of 10
DioRox
Guide
My specific model wouldn't come up in the Associated Products, but it's... Netgear Nighthawk AC1900 Smart WiFi Router, Model: R6900v2
OS on my device is Windows 11. I can't tell you the firmware version of the router, because I can't log into it anymore. I'm not aware of how else to find that information. I can say that I'm sure it's fairly current, as I do keep that updated. The environment is simply a residential home network.
Would I like help? Sure! But I also think it's important for people to hear customer experiences. Having a Netgear tech basically laugh at me was discerning. I'm not going to open my wallet to them ever again. I should have never switched from TP Link. At any rate, I know they won't talk for free, but I was very taken back when he explained to me that the 'securities' they put in place would quit working and knowingly prevent me from accessing my router any longer after a 2 year period. I think it's a pretty deceitful practice. I still haven't received the call back from a supervisor I requested. So.....
I made some changes to passwords, my SSID, rebooted it, and can't get logged back in. The app won't connect to it either. This is in a rental of mine, so I change passwords between tenants. I'm not sure what else I can share. IP of 192.168.1.1.
Thanks.
Message 3 of 10
Guru
Have you factory reset the router and setup from scratch using a wired PC and web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 10 seconds then release.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
Message 4 of 10
The firmware is also visible in the Nighthawk app, but that probably doesn't work for you either.
The first challenge is to work out why you can't login to it.
The most important missing detail is the make and model of the modem/ONT/gateway that sits between the router and the Internet.
You also don't tell us what happens when you try to login to the router. If this is a Windows PC and it is blocking you, that may not be anything to do with the router.
By all means tell the worlds what you think, but 90 percent of the large slab of text you posted had nothing to do with your technical issue. Nor was it obvious to me if you wanted help.
Are you sure that it was someone at Netgear? Many complaints like that here turn out to be from people who did a web search and ended up with one of the crooks who try to con people out of their money.
How do I identify an official NETGEAR website or social media account? - NETGEAR Support
Message 5 of 10
DioRox
Guide
I have not factory reset the router, as I didn't have time. It was just a simple password change that I would do regularly. I frequently log into my routers, at my rentals and at my home. I have port forwarding set up, etc. Never had any issue like this after a reboot. I had a new tenant moving in later that day so I didn't have time to reset it and reconnect all the devices before they would arrive. I have electronic/wifi locks on the doors and it's not a timely thing getting those reconnected. So, yes, I still need to try a reset. But now I will have to wait until this tenant leaves, which is not until March. The modem is provided by Spectrum, it's a Docsis EN2251.
Message 6 of 10
DioRox
Guide
No as I stated, the app does not work either.
My modem is a Docsis EN2251.
When I try to log in, I get the standard error of 'Hmmm.....can't reach this page. Took too long to respond. Err Connection Timed Out.'
Yes it's a Windows PC. I can't fathom it doesn't have to do with my router because the problem began the moment I rebooted it. I've logged into this router and rebooted it many times in the past, never an issue. I've also tried with a completely different windows laptop as well, same result.
I'm fairly certain it was Netgear, as they had my purchase information, and I called them directly.
Message 7 of 10
Guru
You'll need to do a factory reset and setup from scratch with a wired PC and web browser:
Message 8 of 10
Docsis is a (cable modem) technology. It isn't a brand.
EN2251 is probably a Hitron modem, no router component. So that should rule out one source of problems.
A ubiquitous error that could many things.
You've changed the wifi password. No change to admin password? Is that a wired connection with a PC?
Is this local login to the router or over a remote link?
That sentence is a bit broken, so I can't work out what it is telling us.
Rebooted what? Router? PC?
What doesn't have to do with what?
If a problem starts after a reboot, I tend to go with the connecting device as the likely source of the problem. But you seem to have ruled that out.
That looks like a bit of complicated configuration, especially if you don't have immediate access to the router and it is open to the user to fiddle around.
We are talking about a pretty basic and ageing (2017) router here. A lot has changed since then, especially in the area of remote access to devices, if that is what you are using. Too many players in the middle.
You may be using consumer end hardware and techniques that would be better handed with business grade kit.
Message 9 of 10
DioRox
Guide
Docsis is a technology: "EN2251 Hitron Technologies, Inc. DOCSIS 3.1 eMTA. Input 12V". That is printed on the bottom of my modem.
I did not change the admin password. I only changed the pw to the Guest User Wifi. I did this with a laptop, which is the only way I've managed this device for the last 2 years. I have never had a desktop in this rental.
No, my login is not over a remote link. I try to login while I'm already connected to the LAN. Same network.
My broken sentence that you can't decipher, I'm not sure how else to say it.
You stated: If this is a windows PC and it is blocking you, that may not be anything to do with the router. My response is: I can't fathom that it doesn't have anything to do with the router. Reason being, is that it happened the moment I rebooted my router from changing the guest PW. I do not think that a windows device is the culprit.
Yes, I've tried with multiple devices to connect to the router. Same result.
I didn't mean to insinuate that I have port forwarding set up on this router. Again, I have multiple Nighthawk routers, at multiple different homes that I own. I'm simply trying to relay, that I frequently log into all of my routers. Some I do have port forwarding on, some I do not. This one is a very basic plain jane set up. The tenants do not have access to mess with it. While this router may be considered aging to you, I bought it brand new in November of 2022.
I have a Cisco 48 port POE switch along with a 48TB Synology NAS, AvertX CCTV system, Monoprice amplifiers, etc.  racked in my 48u rack in my personal home, all running with an older Nighthawk. I don't need a business grade kit for one router with only 5 connections to it.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2721 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
