Orbi WiFi 7 RBE973
Reply
Firmware update file not found
Janosh
Guide
I try to download latest firmware version 1.0.0.124. Following the link, the message "File not found" appears. What to do?
Model: R7500v2|Nighthawk X4 AC2350 Smart WiFi
Message 1 of 10
Accepted Solutions
Janosh
Guide
Re: Firmware update file not found
Firmware Version 1.0.0.124 is nog available,
Message 8 of 10
All Replies
antinode
Guru
> [...] Following the link, [...]
   Copy+paste of the link might have been nice.
> What to do?
   Contact Netgear (again)?  Yours seems not to be the first such
complaint.  See, for example:
      https://community.netgear.com/t5/x/x/m-p/1540845
Message 2 of 10
If you have the R7500v2 described in your footer, that is not the right firmware.
That should be Firmware Version 1.0.3.26. There has never been a 1.0.0.124.
There is firmware and a manual for the R7500v2 somewhere at the end of this link:
>>>> Nighthawk R7500v2 | AC2350 Smart WiFi Router | NETGEAR Support <<<<
If that isn't your device, look at the label on the back and check the model number.
Message 3 of 10
Janosh
Guide
I am sorry, my type is R7500.
Message 4 of 10
There is a manual and stuff for the R7500 somewhere at the end of this link:
>> Click here >> R7500 | Product | Support | NETGEAR << Click here <<
R7500 Firmware Version 1.0.0.124 | Answer | NETGEAR Support
Message 5 of 10
Janosh
Guide
Of you follow your link and try to download the update file, the message “ File not found” appears. That was the reason I started thuis toppic......
Message 6 of 10
You didn't help yourself by starting this topic with the wrong model number.
These people got it right:
R7500 Firmware Version 1.0.0.124 not found - NETGEAR Communities
A search of the forum before you asked your question might have got you a quicker answer.
Message 7 of 10
Janosh
Guide
Message 8 of 10
From reports elsewhere, I think that means "now" available.
Message 9 of 10
Janosh
Guide
You are right! Autocorrect Dutch fooled me ....
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2107 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
