taki7's avatar
taki7
Follower
Mar 13, 2023
How do you Whitelist, add IP address- Netgear 7550
How do I whitelist a set of IP addresses given by my PCI compliance company so they can run the ASV scans. I was told I need to add the 2 IP addresses they gave me to the "allow" list on my modem settings and have No clue how to do that. I called my internet provider and they couldn't help. HELP...Anyone know how? I have a Netgear 7550.
Below are the pictures from my modem settings. Is this the right area I need to be in?
Do I click on "Add Rule"...and,,if so..how do I Fill in all those sections?
Any help would be greatly appreciated its been hours and don't know what to do.
Thanks!
1 Reply
  • michaelkenward's avatar
    michaelkenward
    That's not a Netgear model I can find in the system. Do you mean R7500?
    Look at the label in the thing.
    What's ASV? Whitelist for what?
    Modem settings? The R7500 is a router. If there is a modem on your network, tell people what make and model it is.
    PS Alt+ Print Screen beats pointing a camera at a computer screen.
