Javihache
Aug 29, 2020Aspirant
IPv6 not working with German provider PYUR
So guys,
I've been fighting to get IPv6 to work with my router. My ISP provides IPv6 Addresses, but the router only receives them randomly or not at all. When I flash FreshTomato 2020.5 on the router IPv6 DHCP works fine selecting 60 or 56 as the prefix length. With an ASUS RT-N56U IPv6 works if I choose Stateful NA-IA DHCP for the WAN IPv6 Address.
As for the R8000 with original Netgear Firmware... the router will get an IPv6 Address once every 500 reboots and/or FW reinstalls, modem reboots... there's no real pattern on when the Router will get an IPv6 using DHCP. It does, sometimes, but 99% of the time it just shows "not available". Am I missing something? Is there a way to make IPv6 work stable?
My ISP says they are delivering IPv6 and the problem lies on my router, which is clearly the case. More specifically on the Firmware, which allows for zero options for IPv6 DHCP. As mentioned, DD-WRT and FreshTomato work perfectly with IPv6. Before you ask, the Wi-Fi performance of those Firmwares is terrible, that's the reason I want to use the Netgear original FW.
Thanks for your help!
For everyone having the same problem with IPv6. Through trying to find a solution for the problem explained here https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Nighthawk-X6-R8000-wifi-5g-second-not-working/td-p/1771235
The user at the very end mentions that 1.0.4.46 solved "the IPv6 Problem" for them.
I tried this firmware and effectively solved the IPv6 Problem and the Second 5GHz Radio disappearing problem.I have deactivated Auto-Updates seeing that Netgear tends to break more than they fix with the firmware updates. I recommend everyone deactivating auto-updates. If it's not broken, don't fix it.
- JavihacheAspirant
By the way! I forgot to mention I am on latest Firmware 1.0.4.52
- JavihacheAspirant
- JavihacheAspirant
Ok, spoke too early. Once the router has been rebooted, the IPv6 Address is gone and there's no way to make it work again. Also V. 1.0.4.46 doesn't work fine with the second radio. Seriously, what a **bleep** firmware Netgear offers. It's definitely the last time I buy a Netgear product.
