Orbi WiFi 7 RBE973
Reply
Logging not working after firmware update
entirelynutz2
I have a Nighthawk RAX120v2 Wifi router.I recently updated the firmware to V1.2.8.40. ever since then the only entries I see in the log file are DHCP IP: entries, and supervisor logins. I'm not seeing remote connections coming in to my router or DoS attempts. I have all options checked for logging.
Port forwarding is working as I see connections in my IIS logs.
Any suggestions as to how to get the logging back to where it was is appreciated.
Message 1 of 4
microchip8
Master
Re: Logging not working after firmware update
Logging is not configurable. Nothing you can do about it as there are no options.
Routing: NETGEAR RAX43 - Firmware: v1.0.15.128 (1 Gbps down, 40 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (GS116v2) / 2x NETGEAR PL1000v2
Desktop: AMD Ryzen 9 5900X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
Message 2 of 4
entirelynutz2
It reported all kinds of traffic before the firmware update.
Message 3 of 4
Kitsap
Master
Firmware updates very often make changes to the router log feature.  I do consider the enable/disable selection of events to be a configuration.  With different routers and different firmware updates, some of the events have become non functional.  How many versions of firmware did you jump from old to new?
Anytime you perform a firmware update and there are issues after the update, the first course of action should be a firmware default reset.  I know it is a PIA, but it has proven to be the most effective and efficient course of action to correct problems with a router.
My setup: Xfinity -> Netgear CM2050V -> Netgear R9000 (Voxel V1.0.4.71.1HF)
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 283 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
