- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Login Page Dead with Chrome - Edge works
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I try to log in to 192.168.1.1 with Chrome, I get
192.168.1.1 refused to connect.
However, if I reboot the router and use Edge, I'm able to log in. If I try Chrome again, I get the above error and Edge can't connect any more. I have to reboot the router to regain access to the login page. Once it's rebooted, I can only use Edge to access it. Once I use Chrome, it kills access.
Anyone know how to fix this? Seems Chrome is causing an issue.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I finally figured out the problem. Turns out I had a HotSpot Shield add-on on Chrome. When I first connect to the router using Chrome, the add-on probably does something causing the router to block all traffic to 192.168.1.1. I uninstalled the add-on, rebooted the router, and now all is fine.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Login Page Dead with Chrome - Edge works
Is it possible that you've told Chrome to remember your credentials for that address a long time ago (different router, different password) so it is automatically trying to login and failing? Try going to Settings... Advanced Settings... Passwords and Forms... Click Managed Passwords link... Uncheck Auto Sign-In and then try again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't think this is the problem. The first time I use Chrome, I can no longer access the login page from any device or any browser. So it looks like the router is refusing all connections to 192.168.1.1.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi _Rajendra_,
Try resetting the router to factory default. Check for the firmware and update it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It has the latest firmware. I don't want to do a factory reset and lose all of my configuration settings. There has to be another way to do this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
7Hi _Rajendra_,
Try to do back up on the settings on the device then reset. I do not have issues with my R7000 when accessing the UI.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi _Rajendra_,
Good to know it works now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks a lot....You are a life saver.Had the exact same problem
