Orbi WiFi 7 RBE973
Reply
Need replacement AC5300/R8500 power adapter...where do I get an authorized one?
Mordred478
Follower
  I need a real, Netgear replacement for the power adapter for my AC5300/R8500 and can't find one anywhere. The only thing I found was fake, Chinese knock-offs on eBay, which I will not buy. Does anyone know wherer I get an authorized power adapter? Thanks.
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: Need replacement AC5300/R8500 power adapter...where do I get an authorized one?
Hi Mordred478,
You can use any power adapter for as long as you follow the specification of the router's power. Check the post below.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/need-r8500-Power-adapter-replacement/td-p/10...
Message 2 of 3
All Replies
JamesGL
Master
Hi Mordred478,
Message 2 of 3
JamesGL
Master
Hi Mordred478,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4128 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
