VTMartha1's avatar
VTMartha1
Netgear Nighthawk 8500 can't log in to change settings
Hello,
I have a Netgear Nighthawk 8500 which seems to be working fine.  I'd like to share a usb drive on it but not having much luck.  Using the Netgear genie, I cannot log in to the router so I can't access ready share or other options.  The Nighthawk app on my iPad isn't solving the problem.  Somehow, I was able to update the firmware so I know that's up to date.  I've tried a number of user name password combinations, including the default (which I don't recall changing).  Changing the login seems to require that I enter the old one.  This is all on a Mac.  Any and all help appreciated.
Thank you!
Martha
