Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk AC1750 Smart wifi. model # R6700v3
mdross1
Hi,
 Our current wifi is horrible a lot of lost calls. Really anxious to install this Netgear because of alll the other changes that have to happen with it. We are not computer people. Was hoping we could keep our old long on password to lessen the aggravation.
Mike
Message 1 of 4
Guru
Re: Netgear Nighthawk AC1750 Smart wifi. model # R6700v3
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 or 149 to 161 channel on 5Ghz.
You and use same SSID name and Password from your old wifi router if you like.
Message 2 of 4
mdross1
Our provider is Spectrum using their modem and latest wifi 6 router. Everything else you mentioned would need help with. Thank you for the reply.
Message 3 of 4
This does not tell us what "their modem" is – the make and model number?
The fact that there is also a "latest wifi 6 router" complicates things. Again, what is it?
The Netgear R6700v3, not one of the most "powerful" routers in the range, may well be no better than your existing router. It isn't wifi6, for example.
Talk of changing wifi bands might work, but is rarely a solution to troublesome wifi.
I would play around a bit to see why you have these "lost calls". Do they happen wherever you are, or just far away from the wifi source?
How big is the area you are trying to fill with wifi? Are there any (wifi) noisy neighbours invading wifi signals.
As @FURRYe38 says, you can change the wifi access settings to whatever you like.
How do I change the WiFi password or security level on my NETGEAR router? | Answer | NETGEAR Support
How do I change my NETGEAR router password or network name (SSID)? | Answer | NETGEAR Support
Or visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Specify Basic WiFi Settings.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1382 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
