- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear R8000 — Nighthawk X6 AC3200
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi I was bought used Netgear R8000 — Nighthawk X6 AC3200 Tri Band WiFi Gigabit Router. But unfortunatelly WAN port didnt work (I call to provider and he said not saw link from my WANport , but he saw link from my LAN ports when i insert the cable in any LAN ports). Say me PLEASE how I can change settings of router and create new WAN port from ones of my LAN port?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear R8000 — Nighthawk X6 AC3200
The first thing to do with a second hand device is a "factory reset".
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
.... how I can change settings of router and create new WAN port from ones of my LAN port?
Not sure that I understand that bit – the WAN port is the one marked on the back – but when it comes to the settings, start with the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What modem/gateway is it connected to?
Did you try testing it on itself?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes.I was try....As I said WAN port died...But LAN ports alive all. How I can do WAN port from LAN port?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Yuri_81 wrote:
Yes.I was try....
What was the result?
Maybe that bit of your second hand router is dead. Perhaps that is why the original owner sold it.
Netgear's routers rarely, if ever, allow users to turn a LAN port into a WAN port.
What do they mean by "he saw link from my LAN ports when i insert the cable in any LAN ports"?
Just because the LAN ports work does not mean that there is a connection between the WAN port and the router. If your R8000 is bust, it is bust.
I hope you didn't pay much for it. Netgear released this device in 2016.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As I said is issue with WAN port. Is 4 working LAN ports (the same type rj45).
I asked How can I remap the ports programmatically.( This for example was possible on the old TP link)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Check under router ip address/debug.htm to see if there is a Mirror WAN to LAN option there...
- Mark as New
- Bookmark
- Subscribe
- Permalink
No you didn't. You said nothing about "programmatically".
You asked, several times, "How I can do WAN port from LAN port?"
Only some Netgear routers have that sort of feature built in.
As @FURRYe38 suggested, go to:
Look for something like
WAN Port mirror to LAN port 1
This is what I get on the R7800.
