Orbi WiFi 7 RBE973
Reply
Nighthawk R8000P won't accept new devices
Lakeman46
Tutor
My router isn't accepting any new devices. All older devices that I have on it are working fine.
My firmware is up to date. My WPS is on, I've reboot the router and powered down the modem. All old devices come back on. Also I'm not showing any signal strength on the router nighthawk app.
I purchased a new Deco AX3000 router. It also says can't connect to the internet.
Looks more like my provider Co-Mo Connect modem may be the problem. My router is 5 yrs old. I've had the provided modem over 8 yrs.
Message 1 of 11
Accepted Solutions
Lakeman46
Tutor
Re: Nighthawk R8000P won't accept new devices
Firmware is 1.1.4.94
Not sure about gateway
15 devices
Not using Smart connect
I was trying to connect wyze V3 cameras on 2.4 gig.
Message 3 of 11
All Replies
Guru
What firmware version are you on? The latest doesn't help
what modem/gateway is it connected to?
How many devices are connected?
Are you using smart connect?
Message 2 of 11
Lakeman46
Tutor
15 devices
Message 3 of 11
Guru
@Lakeman46 wrote:
Firmware is 1.1.4.94----Maybe you mean 1.4.4.94? If not, you are outdated by quite a ways.
Not sure about gateway----Thats important to check. A double nat can cause issues.
15 devices---should still be able to add devices.
I was trying to connect wyze V3 cameras on 2.4 gig.Is the wyze giving you the errors? did you contact th em?
Message 4 of 11
Lakeman46
Tutor
It is 1.4.4.94 sorry
I don't know how to check the gateway. The cable connects from the modem to the router.
I tried 3 wyze v3 cameras and all said the same thing can't connect to wifi.
I've tried to connect other cell phone to my wifi calling, says the same thing can't connect. No new device will connect.
Message 5 of 11
Guru
What modem is that? that's the key. It should have a label on it.
do you have ipv6 enabled?
Is the phone on 2.4ghz during setup of the camera's?
Message 6 of 11
Lakeman46
Tutor
The modem is a Calix 836GE RGS
How do I check if the if the ipv6 is enabled.
I'll probably have to check it on my netgear app on my PC.
The phone is on 2.4gig when connecting cameras.
I have to run some errands and won't be back tell later this afternoon.
Thank you for helping
Message 7 of 11
Guru
From what I could find, that calix is a modem/router combo device. It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-M...
Message 8 of 11
Lakeman46
Tutor
My internet provider Co-Mo Connect is coming tomorrow morning to checkout the Modem and backup battery to the system.
I'm going to hold off doing anything to the router tell Co-Mo looks at the modem.
I'll let you know what he finds.
Thank you
Message 9 of 11
Lakeman46
Tutor
Co-Mo Tech replaced the modem with the newest model. System is up and running now.
Thanks for your help.
Message 10 of 11
Guru
Glad you got it working!
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 680 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
