LeadPipe's avatar
LeadPipe
Nighthawk R8000Pturn on IPV6
Hi I have a P8000 and I’m trying to turn on IPv6 to run an Xbox series x. Is there a way to turn this on? The version I have is V1.4.4.94. My ISP is Hotwire communications. I have very little technical knowledge.
Thanks in advance!
  • Tech was here made a bunch of calls and determined IPV6 isn’t available yet. “It’s something we’re working on”. It’s 50/50 if it’s actually not turned on or they just wanted to get rid of me. But anyway thanks everyone for the help.
    Thanks in advance!
    Couple of questions.  What is the brand name and model number of the modem/ONT connected upstream between your router and the internet?  Does your ISP support IPv6?
    If yes, proceed.  Log in to the router user interface, go to the Advanced Tab -> Advanced Setup -> IPv6.  Under connection type, select either DHCP or Auto Detect.  Under IPv6 DNS, select get automatically from your ISP.  Under LAN setup, select use DHCP server.
    Once you make the changes, you should reboot your router.
    • michaelkenward's avatar
      michaelkenward
      Kitsap is spot on with the general advice, but be warned that IPv6 comes in various flavours and not all Netgear routers support all of them.
      For example, my R7800 does not support the IPv6 implementation that BT uses in the UK.
      Fortunately, my current Netgear router has an "auto" setting that detects BT's implementation of IPv6.
    • LeadPipe's avatar
      LeadPipe
      I have a call into my ISP the agent that I talked to “thought” it was supported but they are having a tech call me back. I made the changes it the router but it says
      “Router,s IPV6 address on WAN not available”.
      this is a fiber optic line so I would be surprised if it wasn’t supported..
      thanks!
      • Kitsap's avatar
        Kitsap
        Master
        thanks!
        Repeat question:  What is the brand name and model number of your Optical Network Terminal (ONT)?
        I agree, I would be surprised if your ISP (Hotwire Communications) does not support IPv6.  It should also be fairly standard support coming from Florida USA.
        First step would be to power down your network and restart it in sequence.  Pull the power cord on your ONT, router, and game station.  Wait a few seconds and power up your ONT.  Give it plenty of time to boot and stabilize.  Now power up your router and give it plenty of time to boot and stabilize.  Power up the rest of your devices.
        If you are using a Windows computer, go to the task manager and look at the network connection section under the performance tab.  It should show an IPv6 address for your computer.
      • Kitsap's avatar
        Kitsap
        Master
        LeadPipe wrote:
        It’s a Nokia model XS-250X-A
        thanks
        This is specifically why I asked.  Your Nokia XS-250-A is a combination device.  An optical network terminal and a router in the same box.
        When you connect your R8000P downstream of your Nokia you are cascading two routers on the same network.  A configuration that will give you much grief.  Commonly known as double NAT.  You need to read here as to why it is not recommended.
        https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
        To correct the situation, you are going to have to dig in to the configuration of your Nokia XS-250-A or configure your R8000P as a wired access point.
        If you choose to set your R8000P as an access point, some of the features will no longer be available.  See here for details.
        https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
        There may be information available from your ISP or Nokia support world that will provide details on how to connect a second router downstream.
        You are most likely correct in thinking a router is blocking your IPv6 configuration.  But, it is not the Netgear router.
