- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X4 R7500 AC2350 DNS problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can someone pls help me?
When I turn on "Enable Access Point Mode"
I get this dns problem and cant use the router. I can only connect to the second router that I have in my network.
The nighthawk is the first router and the other router that I can connect to is the second.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk X4 R7500 AC2350 DNS problem
You need to have something on the network controlling dns/dhcp/net.
so if you put a router in AP mode, it disables all that and it relies on a different router to control it.
so it needs to go modem/gateway/routing device------>router in AP mode
And the device in AP mode, needs to come after the router managing it. Not before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
correct. the first "router" connected to the modem should be in router mode. 2nd one should be in access point mode.
What is your full setup?
What modem/gateway do you have?
then what router?
Then you're connecting the r7500 to that router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My second router is a dovado pro, old (2015)
But cant find access point in that one, guess it called something else, dhcp maybe?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes my first router after modem is the netgear nighthawk x4.
second is my dovado pro
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, but...
I want to change my dovado to ap mode... that is what I need help with.
Pls read from the top.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Contact the Mfr of that device for help and information regarding there product. They will have what you need.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Pls, read from the top.
- Mark as New
- Bookmark
- Subscribe
- Permalink
IM sure if you do a search online for that other router brand that you'll find the information you seek.
Good luck.
