Orbi WiFi 7 RBE973
Reply
Nighthawk X6S R8000P AC4000 USB Disk no more available since upgrade to 1.4.0.10_1.2.14
Erikrm
Guide
Hello,
Since the last firmware upgrade I made 3 days ago to firmware version 1.4.0.10_1.2.14 the external USB disk is no more available/shown in the ReadySHARE Storage interface.
The external USB disk worked perfectly before, I used it for Windows backups and file archive.
It is a Western Digital MyBook 8TB, connected to the USB 3 port of the router.
The computer is a Windows 10 Pro.
Am I the only one with this issue?
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 7
Accepted Solutions
Erikrm
Guide
Re: Nighthawk X6S R8000P AC4000 USB Disk no more available since upgrade to 1.4.0.10_1.2.14
Hello,
Netgear finally made a new firmware that is working just perfectly!
All previous issues have been solved.
Firmware Version V1.4.1.24_1.2.20
GUI Language Version V1.4.1.24_2.1.46.1
Very good, but next time please make more tests before releasing new firmware versions.
Message 7 of 7
All Replies
Erikrm
Guide
Hello again,
The only I found so far, has been to downgrade to the previous firmware version 1.3.0.10_1.2.2 and the external USB disk is working fine again.
I hope Netgear will make corrections with a new and better firmware update.
Message 2 of 7
bmzero
Same issue for me. My USB drive is a 8TB My Book.
Downgrading the firmware fixed the issue for me as well.
Message 3 of 7
Erikrm
Guide
Hello bmzero,
Do you use the Access Control on the router?
If yes, did you have issues with this function you too? (I created another discussion about that)
I hope Netgear will soon find a solution for those issues.
Message 4 of 7
bmzero
I do not. For my needs, the older firmware should be fine. I'll try the next one that comes out. Good luck with your issues.
Message 5 of 7
askeddie
Tutor
I have the same issue when attempting to use my WD EasyStore 8TB external drive with my R7900P/Nighthawk X6S. It will not connect/acknowledge that a USB disk has been connected to the router's USB port.  This occurred after upgrading to firmware version 1.4.0.10_1.2.14.
Model: R7900P|Nighthawk X6S Smart WiFi Router with MU-MIMO
Message 6 of 7
Erikrm
Guide
Hello,
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2011 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
