Jamie242's avatar
Jamie242
Nighthawk gaming router power cord
I have a nighthawk AC2300
model R700P.
I lost my power cable in a move and need to get a replacement, don’t know which one would be best and can’t seem to find one on netgear website, and suggestions?
    • michaelkenward's avatar
      michaelkenward
      As usual, plemans is on the case.
      I step in only to suggest that you may have something suitable lying around. Those power bricks/wall warts are pretty universal. I have even used adapters for USB boxes to power routers.
      Any generic adapter will work. Just get one with the right volts, enough amps and a tip with the right (+/-) polarity and dimensions to fit your hardware.
      The details you need should be on the old adapter, on a label on the device itself and in its manual.
      Your description is a bit muddled. Which could confuse your search for the correct details.
      The R7000P (not R700P) is not a gaming router. (They are XRXXX models.) And AC2300 just tells us about the wifi technology on the thing.
      No matter, the adapter for the R7000P is much the same as those for many of Netgear's similar devices.
        michaelkenward
        A local electronics shop would have been great in the days of RadioShack.
