Reply
Portfowarding on R7000
deef
Portforwarding is not working with Ziggo Connect box
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 8
Accepted Solutions
deef
Re: Portfowarding on R7000
I resetted the modem And router. Now its working.
thanks for Your support.
Message 7 of 8
All Replies
Guru
What is your ISP?
What is your ISP modem mfr and model#
If your using PF configurations, be sure to disable uPnP.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 8
deef
ISP = ZIGGO
ZIGGO Connect Box
How can i call the dutch helpdesk???
Message 3 of 8
Guru
Need to find out if your ISP Modem has a built in router or not. If not, then the R7000 should work well with out any configurations needed if you leave uPnP enabled.
From what I can tell, I think your modem has a built in router:
https://www.ziggo.nl/klantenservice/wifi/modem/connect-box/
I'd see if this unit has a DMZ and put the R7000s WAN port IP address in to the modems DMZ.
Might check with your ISP to see if this modem can be fully bridged. If not, use the DMZ option above.
Message 4 of 8
deef
My ISP modem has a router, but i deactivated it.
So i use my netgear as router.
Message 5 of 8
Guru
What is the IP address the R7000 is getting on the WAN port?
Message 6 of 8
deef
Message 7 of 8
Guru
Good Luck.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2426 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
