Orbi WiFi 7 RBE973
Reply
Ports Closing on Netgear Nighthawk X8
Myiah
Hi.
I have an Nighthawk X8.  I have port forwarding setup on the router along with static ip address saved for different devices on the network. We also use filemaker remotely. Every so often I have to reboot the router  in order for the port to open back up. It is like it has to refresh. Once it reboots we are able to connect remotely again.
What could be the problem with this? any suggestions will help.
Thanks in advance
Model: R8300|Nighthawk X8 AC5000 Smart WiFi Router
Message 1 of 3
antinode
Guru
Re: Ports Closing on Netgear Nighthawk X8
   Is that accurate?  Firmware version?  Connected to what?  (Some kind
of modem or ONT, or another router, or what?)
   For the usual problems with port forwarding, see:
      https://community.netgear.com/t5/x/x/m-p/1859106
Message 2 of 3
Myiah
We are connected to filemaker remotely on port 5003
We can connect just fine. Its just every so often we have to reboot the rooter because the port closes and we cannot connect.
But once we reboot the router we can connect again.
Hope that makes sense
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 475 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
