Dervy's avatar
Dervy
R6120 - QoS settings not showing
Hi everyone,
I'm having troubles finding the QoS setting on the router Web interface.
Anyone knows what's up with that?
Cheers
  • plemans's avatar
    I don't have a R6120 so I can only go off the manual and spec sheet. But it doesn't look like I can find any qos services.
    It could be because the R6120 is a base model AC device.
    • Dervy's avatar
      Dervy
      It could be indeed.
      Do you guys have access to this QoS link through nighthawk UI?
