hexcei
Jan 30, 2021Guide
R7000 FW 1.0.11.116 NTP / Router PIN
Hi,
Was curious if anyone has these issues.
1. Manually updating NTP preffered server does not appear to reatin setting.
2. Unchecking "Enable Router's PIN" does not retain.
Thanks!
-Brian
- mpocAspirant
I have the same router, and noticed the same problem. It's kind of annoying. I would like to disable WPS completely, but apparently that's not an option, or just doesn't save the setting.
- DoctorXGuide
For #1, is your time zone GMT? Another user has reported that saving NTP server doesn't work when timezone is GMT.
My timezone is GMT-5:00 and NTP server setting saves OK.
#2 - The Enable Router PIN setting has not been uncheckable for several firmware releases now. I'm not sure why this one is so difficult to fix.
