- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 Not Connecting to Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 Not Connecting to Internet
Are you running the R7000 behind the ASUS router? If so, you might try AP mode on the R7000:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Mdw3998 wrote:
I moved the Nighthawk into the house and plugged it into the Asus and while it's broadcasting and I can connect to it, there is no Internet connection.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset on the router and setup from scratch with it near the host router. Be sure your using good LAN cables. CAT6 is recommended. Swap LAN cables. Be sure to use the WAN port on the R7000 for router or AP mode.
Try a Dynamic or Static IP addressed configuration for AP mode.
Try the R7000 in router mode with the host router, set a 192.168.70.1 address on the R7000 prior to avoid the host router already using 192.168.1.1. IT should see internet even in router mode connected to another router.
And what FW is loaded currently?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Mdw3998 wrote:
I believe it is in AP mode, it's been a while. But I cannot check that out so anything with the router since it will not connect to the internet. I tried connecting it to a PC (no Internet then) with IP 192.162.1.1 and by using the app while on it's WiFi but it needs Internet for that operation.
In AP mode it will not have that address.(See my earlier message.) Your router should have squatted on that.
You need to look for the IP address of the wifi SSID. Then you can aim a browser at that. With luck you will get the browser graphical user interface (GUI) and can check the mode from there.
... and by using the app while on it's WiFi but it needs Internet for that operation.
Not really. It needs an Internet connection to connect to the Internet. It does not need that for you to get into the device over the wifi.
The Nighthawk app is too dumb to do something complicated like that but it might reveal the IP address of the wifi from the R7000.
Another place to look is in whatever your main router shows in its list of attached devices.
Resetting the R7000 – the usual "who knows what is going on?" suggestion – gets you nowhere nearer to understanding what is happening in your network. By all means go down that "brute force" road but don't expect to come out any the wiser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems like something came from Expressvpn then though I'm not sure if they have specific FW for a NG router. Seems like something or someone did something with out your knowledge with the router. Someone has to put files on the router to make any changes.
I recommend that you keep a copy of the NG FW file some place safe along with a saved router config file as well just in case you need a factory reset. Saves time.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
