CTHW
Apr 29, 2016Aspirant
R7000 Wifi issues
My R7000 wifi was giving me 50+ Mb/second. When I upgraded my service from my isp to 100 from 50 my wifi went down to ~38. Tried to reset. Played with channels. No resolution.
Just had a brain storm and turned off the modem's wifi. It was interfering with the R-7000 right next to it. Thank you for your guidance.
- VE6CGXMaster
Wired or WiFi speed? Changed anything with router?
- CTHWAspirant
Wired is about 98 wifi around 30. I rebooted in order to try to see if that would work.
The provider changed my modem but the wired rate is up there.
- VE6CGXMaster
Both 2.4GHz and 5GHz band has same slow speed? Are you using WPA2-AES protocol? WMM enabled? How far is the device from
router?
