Oliver2000
May 15, 2020Aspirant
R7000 orange light
Hi I just bought a r7000 router and I set it up. The problem I am having is that when I turn it on all of the light go white except the light to the right of the power which goes orange I have tried a power reset factory reset everything but it won't go away I can connect to the wifi made by my router but everytime I connect to it there is no internet being provided when I go onto routerlogin.ner it says my IP is 0.0.0.0 on so plz help I have attached a photo of the light
- Which is a modem/router combo device. Putting you in a double nat situation. It'd also explain the light.
https://kb.netgear.com/30186/What-is-Double-NAT
2 easiest options?
1. place the netcomm in modem only/passthrough mode. contact your isp with help doing that to their device.
2. place the netgear in access point mode. it does disable some function but you'd still be able to use the wireless and ethernet ports. It'd just leave the netcomm in control of the routing functions.
What modem are you connect it to?
That's kind of key as that led is the internet led.
- Oliver2000AspirantI'm connected to the NetComm nf10wv (the default one that came with the internet)
- plemansGuru - Experienced UserWhich is a modem/router combo device. Putting you in a double nat situation. It'd also explain the light.
2 easiest options?
