hantrax's avatar
hantrax
Tutor
Sep 09, 2020
R7000 problem
Hi guys,
I have an R7000 modem router, connected via WAN to another modem router (broadband modem)
A few weeks ago I had a problem, the internet led was flashing fast from white to orange.
I did a hard reset and the problem disappeared, now it's back, I can surf the internet.
If I use the android app, it tells me it's offline...
Do I have to do a new hard reset? or is there a hardware problem?
the firware installed is V1.0.10.90_10.2.90
If I buy a new router, can I use the R7000 configuration file to configure the new router?
  • > the firware installed is V1.0.10.90_10.2.90
          https://community.netgear.com/t5/x/x/m-p/1900901#M155834
       I'd try different (older or newer) firmware before condemning the
    hardware.
       That should work if "the new router" is an R7000.
       Cascadung multiple routers is probably a bad idea, too.  What,
    exactly, is your (unspecified) "another modem router"?  Or is it
    actually a "(broadband modem)"?  If it is (or includes) a router:
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Look for "Set Up the Router as
    a WiFi Access Point".
    hardware.
    • hantrax's avatar
      hantrax
      Tutor
      Thanks...I updated the firmware to the new version and now work fine..
      Stefano
