Orbi WiFi 7 RBE973
Reply
R7000 wifi 6
harrma
R7000 wifi 6
On the documantation it says it supports WIFI 6 but it is wifi 5. With the router being the beginning of the WIFI line how is that even possable since it dosnt need WIFI it gives it. It ether has it or it dosn't, as far as I am aware any WIFI divices after the router would need to support it?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 10
Accepted Solutions
Guru
Re: R7000 wifi 6 https://www.netgear.com/media/R7000_DS_tcm148-120132.pdf
@harrma wrote:
What is the difrence?
Difference between ipv6 and wireless?
Wireless is a wireless broadcast standard.
IPv6 and IPv4 are the protocol the lets machines communicate with each other. Like going from computer--->router---->modem----->isp----->website----->etc.
I linked to the wikipedia listing so you can learn  more about ipv6 if interested.
Message 10 of 10
All Replies
Guru
Re: R7000 wifi 6
Where do you see in the documentation that is supports wifi 6?
Message 2 of 10
microchip8
Master
Re: R7000 wifi 6
The R7000 is an old router and certainly doesn't support WiFi 6. Only the new RAX models do
Message 3 of 10
harrma
page 8
Message 4 of 10
DarrenM
Sr. NETGEAR Moderator
I do not see any mention of wifi 6 on page 8
Message 5 of 10
harrma
did you look at the hilighed part from the image I sent?
Message 6 of 10
Guru
Your screen print was a bit blury. looks like you highlighted of the product data sheet. if i pull that up, its highlighing IPv6.
Thats not a wifi standard. Its a communication protocol.
https://en.wikipedia.org/wiki/IPv6
Message 7 of 10
harrma
Message 8 of 10
harrma
Re: R7000 wifi 6
A
nd how do I edit my queshdion?
Message 9 of 10
Guru
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1367 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
