Wiifii2
Nov 02, 2023Aspirant
R8000 Nighthawk X6 won't turn on
I had some problems with my router, mainly that the Internet was kicking out. This happens frustratingly every so often. About an hour later, I notice it hasn't come back on like it usually does. I turn it off to try and reboot it, but upon pressing the power button a second time the system won't turn on. No lights, nothing. I've made sure the LED switch is set to on, and have tried waiting 30 seconds before turning it back on.
Try a different power supply with same volts and amps. If it still fails, router needs to be replaced.
