Iainthompson202's avatar
Dec 03, 2020
R8000 connected to internet but not broadcasting a wifi signal....
Hi, I turned the router off to restart but when it came back on there was no network.
I've tried a hard reset and also logged in to admin. While there I can see a yellow warning triangle on the wifi.
The settings are correct but theres no signal.
Can anyone help before I burn it it and throw it through the window please?
  • plemans's avatar
    Do wired devices work?
    Did the wifi on/off button get hit? push and hold it for 2 seconds.
    What modem/gateway is it connected to?
    Firmware on it?
    • Iainthompson202's avatar
      Iainthompson202
      Hi, thank you so much for replying..
      Wired devices work
      WiFi off button was not pressed although I tried to toggle it to see if that might fix it, it didn't
      It's connected to a Virgin Media Super Hub 3.0
      Running the latest firmware from Netgear
      • plemans's avatar
        Wired devices work
        It's connected to a Virgin Media Super Hub 3.0---Which has its own integrated router function. This can cause a double nat. not saying its the issue but is a potential.
        Running the latest firmware from Netgear--which is?
        https://kb.netgear.com/30186/What-is-Double-NAT
