alaknkstiyo
Sep 11, 2017Aspirant
R8000p QoS not showing up
Hi
I've just upgraded from a x4 to a x6s, recently configured from scrath but I seem to be unable to find QoS and to be able to see which device is using all my bandwidth, do you guys know how to enable it? or does the x6s does not have it? I kind of remember that but not so sure.
Thanks in advance.
Per engineering, QoS will be available in the fourth quarter.
- ElaineMNETGEAR Employee Retired
Welcome to the community, alaknkstiyo
When you access admin page of the router, don't you see it under Advanced and then LAN Setup.
Under LAN Setup, you should be able to see QoS. I believe the router is using Dynamic QoS.
How do I enable Dynamic QoS on my Nighthawk router?
- alaknkstiyoAspirant
Hi Elaine
Thanks for replying, no QoS is shown even in advanced setup, I cannot even se the bandwidth usage when checking attached devices.
