Iww5000m's avatar
Iww5000m
Router won’t allow connection to google nest doorbell
I have a Nighthawk R6400. I cannot get a Google Nest Doorbell to communicate and send video through my router. I previously had the same model of doorbell working properly. When it broke and I installed a new one, it connects to the router and I can see it on my router page as being connected but it shows as unavailable on the google home app. I also have two google cameras that work well on this router. I have tried two new cameras with the same results. The doorbell does connect and stream video properly through my phone as a hot spot. The only factor I haven’t changed is my router.
  • plemans's avatar
    What modem is the router connected to?
    Did you contact google?
    If its connected to the router, I'd contact google. Maybe something needs to be changed with the account
    • Iww5000m's avatar
      Iww5000m
      It’s an Adtran fiber optic modem. I’ve got great upload and download speeds on all the devices and no issues with any other device, even the other non-doorbell google cams. I went through every option with google, and it works as it should on a hotspot. Are there any settings on the router that would allow it to connect but not allow it to let the video through?
