WMM2's avatar
WMM2
Set a default SSID for private wired connections
The NetGear R6230 Router allows one to define 4 separate SSID networks : 1) a private 2.4Ghz, 2) a private 5Ghz, 3) a guest 2.4Ghz, and 4) a guest 5Ghz.  When connecting my laptop to the router via the wireless connection, I'm able to select which of those 4 SSID's I want to use.  However, when I connect to the router via a hard-wired connection, I don't have the ability to choose which network I'm going to be a part of - it defaults to one of the two private network SSID's.  It's not consistent though.  One time it will connect to the 2.4Ghz one and another time it will connect to the 5Ghz one.
How do I configure the router to always use a single private network and not what ever it chooses at any given time?
  • > [...] when I connect to the router via a hard-wired connection, I
    > - it defaults to one of the two private network SSID's. [...]
       What's the actual evidence behind this conclusion?
       I claim that there is only one LAN, and SSIDs affect only wireless
    connections.  A "guest network" can impose some firewall-like rules to
    restrict communication between "guests" and other client devices, but
    there's still only one LAN.  A wired connection in unrelated to any
    (wireless-network) SSID.
       I don't think that the question makes sense.  Do you mean the Windows
    designation of a network connection as "Private" or "Public"?  That's
    independent for every different network connection, wired or wireless.
       What, exactly, are you doing and observing?  More facts; less
    interpretation.
    • WMM2's avatar
      WMM2
      This first image shows my 4 wireless SSID's and no wired connection (CAT-5 cable unplugged):
      1. MiWiFi2 is the 2.4Ghz private network (internal)
      2. MeWiFi is the 5Ghz guest network (external)
      3. MiWiFi is the 5Ghz private network (internal)
      4. MeWiFi2 is the 2.4Ghz guest network (external)
      The second image shows that I turned off WiFi and plugged in the CAT-5 cable.  The wired connection now points to the internal private 2.4Ghz network and the wireless connections are no longer shown.
      The third image shows the Network and Sharing Center and identifies the wired connection as MiWiFi2, a private network with an Access Type of Internet and a Connection Type as Ethernet.
      As stated in my original post, sometimes the private network associated with the wired connection shows the SSID, MiWiFi, which is the 5Ghz network.
      I guess the bottom-line question is does it matter which SSID is displayed for the wired connection.  If not, this is, at best, a misleading "feature."
      • michaelkenward's avatar
        michaelkenward
        The puzzle is how you think the wifi SSID has anything to do with your wired connection.
        It looks to me that you are confusing the name of your local wired Ethernet network with the SSID. Just because they have the same label does not make them same network. It may just the tag that Windows gave your router. This is something that Windows does all the time.
        For peace of mind, try changing the name of the Ethernet network. Or change the wifi SSID and reel back in shock as the Ethernet network keeps its original label.
