Orbi WiFi 7 RBE973
Reply
Solid Amber Light
Kallippide
Guide
Solid Amber Light
Hi,
I am having difficulty with a solid amber light burning continuously on my router.
Yesterday I added a Sengled Hub to control my Smart bulbs. No problems with adding the hub. However, after a few minutes I got a solid amber light on my router.
The Sengled hub cable is in port 1. The amber light is on the front of the router #1.
Everything else works correctly. (My modem is Arris by Xfinity.)
Any help would be appreciated. Thanks.
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 6
Accepted Solutions
schumaku
Guru
Re: Solid Amber Light
As per the fine documentation, p.14 Table 2. LED and button descriptions (Continued):
Ethernet ports 1–4
The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections.
• Solid white or solid amber. A powered-on device is connected to the Ethernet port.
• Blinking white or blinking amber. Data is being transmitted over the port.
• Off. No powered-on device is connected to the Ethernet port.
Message 2 of 6
All Replies
schumaku
Guru
Ethernet ports 1–4
Message 2 of 6
myersw
Master
Ethernet ports 1–4
They probably went cheap on the Ethernet connection. My Netgear Arlo camera base is a 100Mbps connection and gives a orange light indicating 10/100. No more traffic then these will create to the Internet, a 10/100 Ethernet connection is fine.
Message 3 of 6
Kallippide
Guide
Thank you so much for your help. I didn’t realize that the amber light was okay. The router is several years old and I couldn’t find the manual anywhere. Thanks for sending me the info.
Message 4 of 6
Kallippide
Guide
Thank you for your reply. I won’t worry anymore about the light being on!
Message 5 of 6
schumaku
Guru
Great! Unfortunatley this amber LED is kind of an industry standard to indicate the lower negotiated link Speed (typically because the connected device/switch/cable does not allow more). And indeed it looks "worng" for many consumers.
Message 6 of 6
Discussion stats
  • 5 replies
  • 26771 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
