Orbi WiFi 7 RBE973
Reply
Using Both Wired and Wireless with Access Point Setup
jjkatz
Follower
Considering this router to use as an access point on my existing home network (AT&T U-Verse), and I have a quick question. If I set it up as an access point, are the Ethernet ports still available or is it wireless-only in that mode? I want to hardwire my TV to it but use the Wi-Fi for other devices.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: Using Both Wired and Wireless with Access Point Setup
> [...] If I set it up as an access point, are the Ethernet ports still
   The LAN Ethernet ports should work, too.  That'd be true for
practically any router when configured/used as a wireless access point.
Message 2 of 2
All Replies
antinode
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1725 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
