- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Using cable modem/router combo only as modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd like to know how to run my existing modem/router (C6250|AC1600) only as a modem and use a separate router (Nighthawk AX6 AX4300 RAX45). Is there a way to do this?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, you should be able to find a router mode option on the modems web page, should be under Advanced Tab/Adanced Settings
Router mode may say Yes and No. Select No.
May find a Bridge mode option here as well.
Reivew the online user manual for this model modem for this information if you can find it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Using cable modem/router combo only as modem
Ok, I saw that page when I was looking, but didn't think it could be that simple. Go figure. Thanks for the help.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
