Robm65's avatar
Robm65
Initiate
Dec 07, 2020
WIFI Access Point
Hello
I am looking to run a Ethernet cable from my existing  R7000 AC1900 Nighthawk Wifi Router to my home office
[approx 20m ] using CAT6 cable for a Wifi Access Point for use inside the office [ 3 x 3 m ]   . To be used with  3 devices  , laptop , ipad and iphone.  Use is basic computing , emails , web based applications / videos etc plus MS teams and Zoom meetings . Looking at the  WAC104  AC1200 Dual Band Wireless Access Point.
Just wondering if the WAC104 is compatible with the AC1900  or if there in another suggestion .
I have tried range extenders with out much improvement as I think the router is too far away from the extender as there on opposite sides of the house
Cheers
Rob
  • You can go with an extender or even a router and run the router in AP mode.
    I've used that route plenty and it  gives you the option of a backup router in case you need it.
    Or even upgrading your current router and turning the old one into an access point.
    Several options going for you.
  • plemans's avatar
    the wac104 isa solid option/choice.
    the one thing i'll ask is what extenders did you try? Many have access point mode and can be hardwired in. (not all of them but many)
    Might prevent you from needing to buy another device.
    • Robm65's avatar
      Robm65
      Initiate
      Thanks for the reply
      Yeah only very basic used , D-Link DAP-1320  with no option to wire in
      Was also thinking your option with the Netgear AC1750 WiFi Mesh Extender EX6250 which has the wire in option
      Might have to try and see how it goes
      • plemans's avatar
