mamuzzini's avatar
mamuzzini
Where do I find the 8 digit PIN
    • mamuzzini's avatar
      mamuzzini
      Need the security key. I telework and need it for my job
      • FURRYe38's avatar
        You gave us nothing to go off. Like what NetGear product are you referring too?
        To get a hold of support. Click on "MyNetgear" at the top.
        Register an account (or login) and then the device.
        From there you can start the support process. Keep in mind that its only free for the first 90 days.
        There's a support site with access to manuals, firmware, install guides, etc.
        Go to https://www.netgear.com/support/
        Type in your model number and from there it'll take you to the above.
        Its a great resource to start with.
