Orbi WiFi 7 RBE973
Reply
netgear nighthawk R8500 firmware updating with a MAC/Apple
jacqueshousehol
Follower
nighthawk R8500 cant update firmware, nothing is working im a mac apple user
what can I do????
Message 1 of 4
Guru
Re: netgear nighthawk R8500 firmware updating with a MAC/Apple
Use Safari or FireFox or Opera browsers to manually update the FW on the router:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Need to download the FW file from NGs support site first:
https://www.netgear.com/support/
Also this router is EoL as well:
https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/Top-NETGEAR-FAQs-Support-and-End-of-Se...
So no newer FW versions will be forth coming.
Message 2 of 4
what can I do????
This is the  most reliable way to go about it.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Remember, the download is a zip file. When you unpack it, do not try to "run" the firmware, especially if it is an "img" file. A lot of baffled Mac users turn up here after making that mistake.
Message 3 of 4
Guru
What error are you getting when you try?
Screensnips and a description of what you're doing, trying, and where its failing helps us to help you. Otherwise we're just throwing out WAG's.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 434 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
