srhsieh's avatar
srhsieh
orange light
I just bought a nighthawk smart wifi router R6700-AC1750. After setup, I notice that the front panel led display showing an orange light on the LED labelled '1' (locates between 'USB' and '2'). Can anyone tell me if this is normal?
Thx in advance.
  • Sorry about the post. I think that I figured out the reason after reading the other post.
    I pluged in ARLO on the #1 port so it is orange since speed is only 100.
    • michaelkenward's avatar
      michaelkenward
      Yes. The LED for the LAN ports are colour coded.
      100 Mbps = amber
      1000 Mbps = white
      All in the manual.
      If you visit the support pages:
      Support | NETGEAR
      you can feed in the model number and find all the documentation for your hardware.
