- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
router is interfering with my work laptop Cisco voip softphone. delay to the point of not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router is interfering with my laptop Cisco voip softphone, delay to the point of not working. My phone works in my office with no issues. I have tried to hard connect at home as I do at work and no difference. My internet speed is fine as my family does gaming. We also have an Xfinity modem/router combination that the Netgear router plugs into. My office IT is telling me its on my end and not a work issue since I have no issues with it in the office. We have reset routers and modem and direct connection rather than wifi , doesn't seem to make any difference with the phone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: router is interfering with my work laptop Cisco voip softphone. delay to the point of not worki
Not much to go on.
What NG router do you have?
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
Try option #2 first...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
check this out : https://www.nextiva.com/blog/voip-troubleshooting.html/My Fortiva
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
