ForumsSuck's avatar
ForumsSuck
unable to directly connect to my nighthawk r7000.
i have tryed to connect using 192.168.1.1 as well as http://www.routerlogin.net
for the number it just times out again and again,   for the router login,  it says 'your not connected to the wifi   (which of course im not,   im using a direct ethernet connection)
i have no issues connecting to my wifi etc  it just wont let me enter the set up now days  and im not sure why,  any insights on this would be very much appreciated
  • antinode's avatar
    antinode
    Apr 02, 2019
    > [...] mine it seems is 10.0.0.1 vs the normal one listed online. ;>
    > it let me using that
       Ok, but the reason the R7000 shifted from its normal default
    ("192.168.1.1") to that alternate is, most likely, that you connected it
    to some other router (which was already using the "192.168.1.*" subnet).
    > To what did you connect the WAN/Internet port of the R7000?
       Still wondering.
       Cascading multiple routers can cause multiple problems.
          https://community.netgear.com/t5/x/x/m-p/1684723
       Without knowing what your mystery device (modem/router?) is, it's
    tough to give more specific advice.
  • > [...] for the router login, it says 'your not connected to the wifi
       Welcome to what may be the worst error message in the world. For an
    explanation, try:
          https://community.netgear.com/t5/x/x/m-p/1365830
       Briefly, the idea is that "[www.]routerlogin.net" (or ".com") should
    point to your own router, but that's true only if you use your own
    router for DNS name resolution.  Regardless, you should be able to get
    to the thing using its IP address, if you can determine (or guess) that.
    Normally, that would be something like "192.168.1.1", but it could be
    different.
    > [...] 192.168.1.1 [...] for the number it just times out again and
    > again, [...]
       Then either that's not the LAN IP address of the R7000, or its
    management web server had died (possible, but unlikely).
    > i have no issues connecting to my wifi etc [...]
       Does "etc" include a wired/Ethernet connection?
       What is the IP address of one of these successfully connected
    devices?  What does it say that its gateway/router address is?
       To what did you connect the WAN/Internet port of the R7000?  That
    could affect its LAN IP address, especially if you connected it to some
    • ForumsSuck's avatar
      ForumsSuck
      thank you.  mine it seems is 10.0.0.1  vs the normal one listed online. ;> it let me using that
      • antinode's avatar
        antinode
        Guru
           Still wondering.
