× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MS70 Satellite Advanced Config Options
lrsantos
Tutor
When I login to the MS70 Satellite and scroll down the screen, there is an "Advanced Home" section with a bunch of settings similar to the router.  Should I change any of these to optimize the system further, or is it getting an optimized configuration through the sync with the router?
The one thing I know I would like to change is the device name.  When I tried to change it though and hit the "Apply" button I get an error that says "The IP Address conflicts with the WAN IP subnet. Please enter a different IP address."  I didn't change anything but the Device Name in the "LAN Setup" section.
Any suggestions on configuration changes at the Satellite?
Message 1 of 2
Accepted Solutions
Guru
Re: MS70 Satellite Advanced Config Options
If its working fine, I wouldn't mess with it. I don't have the MK system but most mesh systems are designed to let the router manage the satellites for better speeds/efficiencies.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1522 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
