Ceerob's avatar
Ceerob
Follower
Jun 28, 2022
New modem, same mesh
I need to change my modem. Will I have to change all of my mesh settings or can I just plug the Nighthawk MK6W into the new modem, keeping all of my cameras, TVs, thermostats connected? I am doing this remotely with a guest in my home and I want to minimize the work they need to do. Hopefully it is plug and play.
  • FURRYe38's avatar
    No.
    Turn off and unplug modem.
    Turn on computers and rest of network.
  • plemans's avatar
    It should be pretty plug and play.
    get the modem activated.
    then follow the guide FURRYe38  wrote on connecting the router.
    I've rarely needed to do a factory reset on my router after changing modems. Its happened but usually if I'm also changing speed tiers.
