Avekaj's avatar
Avekaj
Follower
Nov 11, 2021
Nighthawk Mesh MR60 not broadcasting SSID
Hey all,
So I have the Nighthawk Mesh system in my home. I have the Nighthawk MR60 (router) and Nighthawk MS60 (satellite). My network is set up like this:
Modem -> Nighthawk MR60 (Router) Wirelessly connected to Nighthawk MS60 (Satellite)
The MR60 had 2 SSID's: let's call it My Network (this is 2.4ghz) and My Network 5 (this is 5ghz). The satellite had one SSID, My Network Mesh. Over the past few days I've noticed that My Network and My Network 5 have disappeared. The only SSID I have now is My Network Mesh. All devices are able to connect, but I liked it better when I had the three independent SSID's. I've gone into router settings and do not see an option to fix this. Can anyone help me get my SSID's back? :(
1 Reply
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
    Try powering OFF the ISP modem and MR and MS for 1 minute or more and then back ON.
    Try changing channels on the MR, try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Thank you.
