- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
URGENT! MR60 Power Supply Fail - Making LOUD buzzing / hissing sound. Still under hardware warranty
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
The power adapter to my MR60 is failing. It's making a terrible LOUD hissing/buzzing sound - plugged directly into the wall. Have tried other outlets in house, same problem.
This feels very unsafe, and it seems it may catch fire at any moment. This is not right, my other satellite is silent and not HOT like this one.
My products are under warranty still, I need a power supply replacement sent for the MR60 - ASAP!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: URGENT! MR60 Power Supply Fail - Making LOUD buzzing / hissing sound. Still under hardware warra
Make contact with NG support:
https://my.netgear.com/support/contact.aspx
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would reach out to a forum moderator and see if they can help you:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Send them your information and they should be able to go from there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That sound coming from your power supply is most likely a capacitor going bad. Most of the time they don't catch fire, as it keeps going bad your router will have issues like slowing down your internet to disconnecting you until you replace the power supply.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd disconnect that power supply pretty quickly. It might be going bad and might not cause a fire but when it comes to that, better safe than sorry.
Check your satellites as they might use a matching power supply that you can use to manage the router until you can get in contact with support/moderator to get help getting it replaced.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
