Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
VLAN Tagging on MK62 on Access Point Mode + Easy Mesh
lostgear
Star
I want to create 2 SSIDs using the MK62 (or other Easy Mesh compliant Netgear routers) and tag then to a VLAN (802.1q) so that my switch can segregate the two SSIDs as separate networks.  Does the MK62 support 802.1q in Access Point Mode (ideally in Easy Mesh mode as well)?
Message 1 of 4
Accepted Solutions
Guru
Re: VLAN Tagging on MK62 on Access Point Mode + Easy Mesh
Not as far as I'm aware.
None of the consumer devices support vlan tagging for anything other than IPTV setups.
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
All Replies
Guru
Message 2 of 4
lostgear
Star
Thanks, that was fast! I was given the runaround in their chat support and never got a direct answer.
Would you know if the Orbi Pro Mini will be able to do this (VLAN tagging in AP mode).  Obviously without the Easy Mesh feature which it does not have.  Tried to post in the Orbiter Pro Section but somehow I'm not allowed to start a discussion there.
Message 3 of 4
Guru
Should be able to start a discussion on the pro forum. Not sure why it won't let you.
Sorry but I more a consumer forum side and my business forum knowledge is sketchy at best. 🙂
Don't want to give you bad advice on the business side of things.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1970 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
