MFL100's avatar
MFL100
nighthawk ax1800 satellite firmware
My M60 router has updated firmware V1.1.6.124_2.0.5.   My satellites have V1.1.6.122 and are not working.  When the router update checked for the satellite firmware, it said no updates were available.  When I try to manually update the satellites from  the V1.1.6.124 router update file on my computer, it says that I already have that installed.
Does that mean that the two satellites firmware was updated automatically when I updated the router?  If not, how do I update the satellites firmware?
  • FURRYe38's avatar
    Did you log into the MS web page there and send the FW file there using a web broswer?
    Also remember to update the MS first before the MR.
    • MFL100's avatar
      MFL100
      I only downloaded the MS60 router firmware update (through my browser) and installed it through the router update.  I just recently learned that the satellites also have firmware that needs to be updated, and Netgear says there are none available after v...122 for satellites.  Of course, when the satellites.don't work, there is no information about their firmware updates on the router web page to tip you off.
