Reply
5G Authentication error occurred.
DeeMe10
Hi. I just purchased Nighthawk AC1900 WiFi Cable Modem Router model C7000v2. It was working fine until 3 days ago. 5G network stop connecting. I got 2 msgs. 1st "Failed to obtain IP address" & 2nd "Authentication error occurred." - l'm stucked on that 2nd one. 2.4 works just fine. Anyway, called Netgear was on the phone for 5 hrs and was told to buy new one. Called Comcast was told the same. For some reason l don't believe l have to buy a new one or exchange it. When l was renting from Comcast (router/modem) l would get the same msgs at least once/ twice a month. They would reset wifi signal and l was good to go until next time. This Netgear Nighthawk model C7000v2 is brand new. I just think they do not know how to fix it. Any ideas???
Message 1 of 14
Guru
Re: 5G Authentication error occurred.
did you try a simple factory reset and reinstall?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 14
DeeMe10
Yes l did. Didn't work!!!
Message 3 of 14
DeeMe10
Yep. Didn't do anything!!!
Message 4 of 14
Guru
is it only wireless devices with that issue?
Do wired devices work fine?
Message 5 of 14
DeeMe10
Both don't work.
Message 6 of 14
Guru
both 2.4ghz and 5ghz? And wired?
You're not being very detailed.
What happens when you factory reset?
Are you able to access the gui through the browser?
Message 7 of 14
DeeMe10
Both 2.4ghz and 5ghz don't work including wired connection. 2.4 works just fine on both ends. (WiFi & wired)
Message 8 of 14
DeeMe10
After factory reset? Same thing. Do not work. Are you talking about Netgear genie? If yes than yes, l can use it.
Message 9 of 14
DeeMe10
2.4ghz works just fine on both ends (WiFi or wired) 5ghz don't work at all including wired connection. I keep getting "Authentication error occurred"
Message 10 of 14
Guru
this doesn't make much sense. saying 2.4/5ghz and wired doesn't work but then saying 2.4ghz works fine on both ends (wifi/wired). that's not how it works.
Are you able to access the routers gui through the browser?
Message 11 of 14
DeeMe10
I meant 2.4ghz works just fine on both ends (WiFi or wired) 5ghz doesn't work at all including wired connection. I keep getting "Authentication error occurred" Can l access "gui?" Yes l can.
Message 12 of 14
Guru
If its new, I'd return/exchange it.
Message 13 of 14
DeeMe10
Thanks!
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 618 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
