datyperry96's avatar
datyperry96
Follower
May 19, 2022
5g wifi but no internet
I have a tri-band R8300 router. Out of nowhere my 5g will connect to the wifi but no internet. I have tried rebooting the router. Unplugging and plugging it in after ten minutes. I went on my phone forgot the network and reconnected. And I updated the router. The only thing that is red on my router is the 3 slot.
In case anyone ask I have a SB8200 modem.
  • michaelkenward's avatar
    michaelkenward
    You get some sort of error message on some device or other?
    Which one is that? The only LEDs on the front that do "red" (amber) are power and Internet. If either of those is amber, you have a problem. A dead router or no Internet.
    What about the 5 GHz wifi LED?
    Tried pressing the wifi LED button?
  • plemans's avatar
    Is anything else plugged into the sb8200? it has more than 1 ethernet port but the vast majority of isp's only allow 1 device to be connected to it.
