- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1200-R6220 VPN Passthrough
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have contacted my IT professional at work and they could not help me (just said "the router's blocking it"), so I have no other choice than to try and fix myself. I am not a computer whiz, but I can get by with guidance.
-VPN works when connected directly to modem.
-VPN does not work when connected to router but it HAS worked previously when conected to router, then one day stopped.
-I have done the "port forwarding" advice. See attached snip, not sure if I did it correctly.
-I am not sure what VPN software they are using. I know it uses "Wan Miniport (L2TP)". I have included snip of program symbol.
-It is the most recent firmware. I tried installing original firmware (1.0.0.14) and middle of the road (1.1.0.66). Neither allowed VPN to work.
-NAT filtered is "secured". I opened to see if it would fix. It didn't
-VPN Passthrough is enabled for IPSex, PPTP, and L2TP
-Respond to Ping on Internet Port is checked
Please help. I have so much work to do and can't access my work network. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1200-R6220 VPN Passthrough
port forwarding snip since I couldn't include two attachments
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can always cheat and put the computers IP address in the routers DMZ. This forwards everything to the router. not a safe option but it'd get you up and running. Everything between the work computer and work should be encrypted through the vpn anyway.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you tell me how I can do that. Thank you.
Any idea on long-term solutions or why the router is doing this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Long term solutions? work with your IT department or contact the vpn program support that they use for assistant setting the proper forwarding.
- Mark as New
- Bookmark
- Subscribe
- Permalink
IT is useless. Any idea on what that program is from the snip? I may have to do a lot of research and set up my own VPN.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not off the limited info. Your IT department should at least be able to give you what vpn provider they use.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did the DMZ thing and had the traffic go to the IP address of this computer that I'm using and it didn't work. May I be doing something wrong?
